ike66
Apr 02, 2017Explorer
yellowing plastic trim
The plastic trim around the door window, awning motors, and stove vent cover have yellowed over time. Is there a way to bleach these back to white or do I just paint them.
Clay L wrote:I had never heard about Softscrub so I did a search. Looks good. THANKS!Gene&Ginny wrote:
I use Clorox Kitchen Cleanup with bleach. Spray it on, go have a cold one ... or 2, rinse. Also works well on the AC outlet covers and grab handle next to the door.
That works but for more stubborn yellow stains I have used Softscrub with bleach. It takes a little work but will remove the yellowing.
blueglide wrote:NYCgrrl wrote:blueglide wrote:
Check out this thread I posted a year ago about the same problem. Be prepared for a few naysayers who have not tried it to tell you that it won't work or is bad because its bleaching the plastic (its not)...blah blah blah. My plastic still looks brand new.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29016049.cfm
It IS "bleaching" as in whitening a surface and the surfaces I frequently use hydrogen peroxide on are natural textiles.
That didn't take long....heres an article, one of many, that explains the chemical process taking place. This one is fairly basic but does a good job of explaining it. This is a chemical stabilization process (bromine stabilization).http://www.mountainouswords.com/mountain-air/retr0bright-restoration-project/
