rileybrake's avatar
rileybrake
110V trailer plugs don't work.
Hi I have a 1994 Kit Companion Sunchaser 5th Wheel and I'm trying to figure out why the plugs inside don't work. The only one that works is the one in the kitchen. There are about 5 or 6 other ones that don't work. This has been an ongoing problem that seems like it comes and goes. We even drove 2 hours back to the dealer only to realize the problem fixed itself. When they plugged it in and tried it worked fine. At first I blamed it on being plugged in with a 100 foot extension cord and it losing so much power over the distance. Although when I took the generator out and tried plugging it directly into that it also didn't work. I Then started to dig a bit deeper. When I tried the outlets with my voltmeter, I get 120V with the power lead in the right hole and the negative lead in the bottom ground plug. With the negative lead in the left hole and power lead in the right, I only get a reading of about 8 Volts. I've tried everything from looking at fuses and breakers to trying to rest the GFCI outlet in the bathroom(which has a green light lit up dimly, but outlet doesn't work) to even trying to find a dirty ground somewhere. I honestly think its a dirty ground somewhere but I have cleaned all the grounds that I could find. I'm out of ideas to try. Does anybody have any problems like this or know of any solutions that I could try. I had one plug out of the wall already but nothing looks out of the ordinary.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
