Aug-08-2018 10:12 PM
Aug-20-2018 09:07 AM
Aug-20-2018 08:55 AM
time2roll wrote:dougrainer wrote:So you are just waiting for a problem to burn the thing out? No thanks, if there is a fault I want power off until the issue is resolved.
Now, if you have a Short, you do NOT install a Auto reset Breaker. ALL that will do is burn out the Auto Breaker. Doug
Have seen posts of these things fail in a closed position or burning up. Does not sit well with me as a safety device. Sure they work fine as long as there is no fault to protect.
Aug-20-2018 08:31 AM
Aug-20-2018 04:50 AM
time2roll wrote:
I do not like auto-reset breakers except maybe for diagnostics.
Aug-19-2018 09:40 PM
Aug-09-2018 03:37 PM
Aug-09-2018 03:01 PM
Aug-09-2018 11:29 AM
GordonThree wrote:
I'll hold my tongue on "auto reset" atc fuses
Aug-09-2018 10:59 AM
Aug-09-2018 10:37 AM
dougrainer wrote:
I advise customers to install a Auto reset 12 volt breaker in place of the ATC fuse. That way, when you have momentary overloads, it trips and then resets within a minute or so and you do not have to keep replacing fuses. They make Auto reset in ATC type. Doug
Aug-09-2018 09:56 AM
Aug-09-2018 09:47 AM
time2roll wrote:
30 amp fuse seems light. I thought most were 40 amp. Check the owner's manual.
Clamp-on DC ammeter will tell the tale if that 30+ amps is actually getting to your pair of AGM. The way people talk about the charge line passing a trickle charge at best of 5 amps would point to a short somewhere. I think the power could very well be getting to the batteries but need to put a meter on it to know.
If the trailer battery is fully charged do you still have the issue?
Aug-09-2018 08:23 AM
Aug-09-2018 07:39 AM
