happy2rv
Sep 08, 2019Explorer
BB_TX wrote:
Are you certain it is not the larger red wire (on the post with the red jumper and smaller white wire) that goes to the battery?
Those breakers should not be in series. Battery should go to both and then each one feed it’s own circuits.
I will double check, but I'm fairly sure the battery the large red wire on the bottom post in the picture. I'm almost certain the large red wire on bottom post of the upper breaker is the main load center inside the trailer.
BB_TX wrote:
Curious why you think the one is “shorted out”. If the breakers are good you will have +12 vdc on both posts at all times except when they trip.
If you look at the full size picture, it's clearer. The ring terminal on the upper post of the bottom breaker is touching the bottom post.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 25, 2025
