enblethen
Dec 23, 2014Nomad
Put a volt meter on the 120 volt output. It can be plugged into a receptacle.
It could be a failing voltage regulator.
You could do it on a 12 volt DC circuit or at the battery as the converter output would rise and fall as 120 volt AC input changes.
