landyacht318
Apr 13, 2014Explorer
12V Lithium Iron (LiFePo4)
I've occasionally found myself in need of a small portable 12v battery.
I was kind of interested in these small lightweight Non Lead Acid "jumper packs' which claim 200 CCA and also have 12v@2 amp and USB 5v@2a and 19v@3.5 amp outputs
http://www.amazon.com/Antigravity-Batteries-Micro-Start-Multi-Function-Personal/dp/B00FDYYK4A/ref=cm_cr_pr_sims_t
http://www.amazon.com/PowerGo-Unbelievably-Portable-Battery-Includes/dp/B00E0UNF4E/ref=pd_sbs_auto_3?ie=UTF8&refRID=0A8Y3EGNDVS8MYZND8QN
Then I came across this product, thought it was interesting.
http://www.amazon.com/Battery-Tender-BTL14A240C-Lithium-Phosphate/dp/B00F9LPJ8S/ref=pd_sbs_auto_2?ie=UTF8&refRID=0K6Z43NQVDAD9J45EBEA
More info
Says to limit charging current to 10 amps and no more than 14.8v, but it is a tiny light battery. I cannot find anything about it limiting the discharge to prevent damage but I assume it must have it.
I'll probably wind up with a small AGM for 1/5 the $$ but I just thought the products above could interest RV.net's battery aficionados , and provoke interesting discussion.
I'm wondering how long before the prices drop to realistic for larger capacity Lithium technology batteries
More info
