- pianotunaNomad IIIMine is a 300 amp catastrophic failure fuse. The fuses are on the positive post of each battery bank (twin banks).
- Itinerant1ExplorerI'm using a 400a T fuse with the 3000w inverter.
- Super_DaveExplorer III was concerned about the fuse on the 12v side
- LwiddisNavigatorDon-
While you and others on this forum may see draws of 180 to 240 amps, I submit that doesn't represent most of us, just like having battery banks of 556 to 875 amp hours isn't what most of us have.
Formerly I had two Trojan T125s...240 amp hours. Now 200 amp hours via my new Lithium battery. - pianotunaNomad III
Itinerant1 wrote:
Lwiddis wrote:
50-55 amp draw at 12 volt is a heck of a draw.
Depending on size of battery bank and chemistry of batteries. My system sees 150-175a daily over the past 5.5 years during meal times.
And mine sees 180 to 240 amps under similar circumstances since 2009. The OEM battery bank was 875 amp-hours (flooded marine) which has been dropped to 556 (AGM telco).
I wanted my RV to behave as if it were on shore power. It does. - Itinerant1Explorer
Depending on size of battery bank and chemistry of batteries. My system sees 150-175a daily over the past 5.5 years during meal times. - azrvingExplorer
Yep. I don’t remember exactly but I think my toaster was about 8 amps which was 80 dc. I usually ran my generator first thing in the morning to power the kerig coffee machine, toaster, microwave and the PD converter to put some of the heavy amps back in the batteries then go to the 1000 watts of solar as the sun improved - LwiddisNavigator50-55 amp draw at 12 volt is a heck of a draw.
- pianotunaNomad IIIGive that the inverter may at best be 90% efficient
5 /.9 X 10 = 55.5 amps
As the voltage drops a good inverter may draw more amps to keep the voltage on the output side to 120 volts--so that 55.5 may become 60 or more amps.
That's one place that Li shine--assuming a 100 amp-hour battery that has a battery management system which allows a 1c discharge.
SiO2 is a good choice too--as they are rated for 4 C continuous. - Yes. Close to 50
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
