โSep-04-2013 02:15 PM
โSep-07-2013 02:14 PM
MEXICOWANDERER wrote:We used to use this same "water/ice-packing" for freezing fresh water fish. It worked extremely well.
Dill, parsley, oregano, thyme, et al
โSep-07-2013 01:40 PM
So, - forget FDA guidelines 0F/18C. These are temps that will keep your food from spoiling indefinitely. You are not going to live indefinitely. If your fridge keeps 40F/4C, and freezer 14F/-10C - this is enough for most vacation trips and more than enough for a weekend trip. Don't lose your sleep over that. Manufacturers have detailed specs that consumers don't usually see - like max 0F in the center of freezing chamber and max 14F at the door, and even those max values you might not get in real life. I am not talking about deep freeze chests that can do -22F, those are different.
โSep-07-2013 12:30 PM
โSep-07-2013 11:33 AM
โSep-07-2013 11:22 AM
TIP. Freeze FRESH herbs in a solid block of ice. Let melt then air dry on paper towels. Cannot tell from fresh.
โSep-07-2013 10:49 AM
โSep-06-2013 12:24 PM
DiskDoctr wrote:
What about adding unfrozen food to the 17F? How long does it take to freeze and how does that affect the foods around it?
โSep-06-2013 02:57 AM
โSep-05-2013 10:08 PM
Chris Bryant wrote:
If the unit can only achieve in the teens in the freezer, that means there is not enough liquid ammonia being produced. If there is not enough liquid ammonia in the freezer section, there sure as heck will not be enough in the lower section.
โSep-05-2013 05:12 AM
โSep-05-2013 04:59 AM
Almot wrote:Chris Bryant wrote:
I'll say that in an absorption refrigerator, seventeen degrees in the freezer translates to unacceptable in the fresh food compartment.
Maybe.
โSep-04-2013 05:57 PM
sh410 wrote:My freezer runs -12F to 0F so I need a hammer and chisel to get at my Ben & Jerrys Chunky Monkey. :B
But what about ice cream!
Reese Dual Cam Straight Line HP Sway Control
โSep-04-2013 05:43 PM
โSep-04-2013 05:34 PM
