westernrvparkow
Jul 29, 2019Explorer
Alan_Hepburn wrote:An RV 30 amp plug will not fit into a 3 terminal 240 volt welding or older style dryer or stove outlet. The 30 amp RV plug has two blades and a pin, while the 240 volt outlet has three blade sockets. That third blade socket is narrower than the ground pin on the RV plug. To make the RV plug fit into that 240 volt 3 blade outlet you either need to modify the pin on the RV plug or use a hammer to force it in.fj12ryder wrote:
But I do wonder about people that say they have plugged into a welder outlet and damaged their RV. Or is that just a case of the outlet wired incorrectly for the welder?
Those people are usually dealing with a 30A RV - some older 240V 3 terminal outlets are close enough to an RV 30A outlet that some people will force their plug into the outlet, with the expected results.
The most likely way anyone has ever damaged their RV is to have either replaced the welder's outlet with a 30 amp RV outlet, thus incorrectly wiring it, or they replaced the plug on the RV with a welding machine plug, again it would be miss wired.
That welding outlet has no neutral, so wiring a 30 amp RV outlet to it would mean there was a hot circuit wired to the neutral blade of the RV outlet. Similarly, wiring a welding machine plug to your 30 amp cord would mean one of those hot circuits of the welding outlet would now be connected to the neutral wire of the RV cord.
