tunabob
Jun 21, 2020Explorer
1995 Bounder F 53 Coolant Tank, Hydraulic Hose
So here is my next project I need advice on.
1. My coolant recovery tank disintegrated a few years ago. I ran to the parts store and bought what they had in stock. In retrospect it may be to small. As long as I check and make sure the coolant tank is topped of on each stop we are good, but at times we do loose some coolant, I am thinking this is at least partially because there is not enough capacity to hold the coolant when the motor get good and warm. I have been doing some research and see where there are 36 oz tanks. any advice would be helpful.
2. I have a leak on the hyd jack supply line, it is on the front right (passenger side). When I did the left one I removed it and took to a shop and they made a replacement. Now I see Amazon sales these and I am asking if anyone knows the size in both length and fitting size. Thanks again. Ken
