wa8yxm
Feb 07, 2016Explorer III
HE does not understand batteires.
Fact: The battery with the LOWER VOLTAGE will accept the lion's share of the charge current. When the VOLTAGE in both batteries (the six volt pair is considered to be a single 12 volt battery) then charging will be shared in exact perpetrator to their size. IF EITHER battery should "Get ahead" (which is basically impossible assumign all connections are clean and tight) It will stop accepting power till the other one catches up.
Likewise when discharging the larger battery will provide, IN PERPURTION the lion's share. so once you go throug one charge/discharge cycle the batteries are in perfect lock step till one of them fails. It is IMPOSSIBLE for one of them to reach full first.. They both get there at exactly the same nano-second.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
