SoundGuy
Jul 13, 2015Explorer
Joel_T wrote:
I'm tripping over dollars probably to save maybe 10a a day. The loss I'd take selling a "new" 300w wouldn't be much different than the added expense to set up the second inverter.
If you're so convinced you want to use both inverters - a 300 watt and a 2000 watt - why not just wire both sets of inputs to the battery, simply plug your trailer's main service cable into the inverter you want to use at the time, just as you would into shore power or your genset, and not bother with a multi position, high current switch at all? :h JMO, but I'd be putting any extra $$$ into beefing up the battery reserve to make better use of the 2K inverter's full potential.
