swhitney's avatar
swhitney
3 position Transfer Switch
I have an older class A RV, I was thinking about installing an inverter but wasn't exactly sure on the wiring.
To me the easiest way if it's even available would be to have a 3 position transfer switch. If I were to be plugged into shore power then that would run everything or vice a versa, if the generator or shore power was not on or plugged in then the inverter would run.
Not trying to power the AC.
Thank you,
Sean
