deltamaster
Oct 12, 2014Explorer
2003 E-450 Cutaway chassisFront ABS sensors and Air bags
If one of the front tires rubs through the ABS sensor cable can it be repaired by soldering the wires back together?
Will it work properly or will the entire sensor need to be replaced?
Will disconnecting the battery clear the code and turn off the warning indicator on the dash?
Several years ago there was a short in the after-market alarm system. The alarm system was removed and the damaged wiring was all repaired or replaced. In order to access the wiring under/behind the dash, the steering wheel had to be removed and the dash had to be removed from the vehicle. This involved disconnecting the airbags.
The airbag warning light has been lit on the dash ever since. I know the system was properly reconnected. Is there a way to clear the code from the computer and turn off the airbag warning indicator? Disconnecting the battery has not been successful.
