opnspaces
Aug 14, 2020Navigator II
I found the manual online. Link
Once you find the inverter/charger there is a light that blinks codes depending on the fault present. See if the light blinks when the 12v power goes out.
Check your house battery, it might be boiled dry and dead. This could cause the charger to put out too much current trying to charge the dead battery and trip a circuit breaker. If so replace the battery and see if the inverter calms down.
