2006 Winnebago Voyage taillight
AggieDad
Howdy
I need to replace the taillight bulb in my 2006 Winnebago Voyage. I see no screws or other fasteners on the lens. I am reluctant to try and pry it off as the entire assembly seems “wobbly” on its mount.
Anyone with experience with this or any thoughts or ideas?
Many thanks,
Don
Be of good cheer!
Don Simmons
2006 Winnebago Voyage 33V pushed by a 2014 Chevy Captiva
Never ask a man where he is from.
If he's from Texas, he will eventually tell you.
If he's not, well... don't embarass him.
2 REPLIES 2
D_E_Bishop
I would bet if you take a bright flashlight beam and look between the lens and the fiberglass, you will see to to four tabs sticking out and catching on the base of the assembly. They are press in and I made a tool for removing the lenses on my Winnie.
If all else fails call David at Lichtsinn and ask him.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
barnaclebill
Different M/H than yours and I accessed the bulb from the rear, in side the rear engine hood. The socket turns 1/4 turn to unlock the socket from the tail lens. Hope this helps, Bill
2009 Monaco Camelot 42PDQ
425 Cummins
Chevy Equinox or Tracker
Blue Ox towing
