CanadaKonrad's avatar
CanadaKonrad
2007 Freightliner M2 106 MBE 900 Allision
Hello,
2007 Freightliner M2 106 MBE 900 Allision Electrical Issues tail end
having some weird electrical issues, right turn signal sticks on (in the back) mostly when running lights are on. Sometimes by pressing the brakes, brake lights come on but turn signal wont. When putting the truck into reverse rear taillights come on (sometimes). Just odd stuff.
Anybody ever hear or had anything like it. Did a bunch of digging, added some grounds, didnt make no difference.
Thanks,
Cheers
  • M2s that we had when I worked always seemed to have issues with the turn signal switch. Goes with the Chrysler ownership I think.
    B.O.
  • Guessing the turn signal switch is going bad, the one thing in common to them all.
  • Fl,s of that era are notorious for electrical problems
    Could be the turn signal switch. I drove an 07 Columbia with the same problems 2 shops failed to fix problem. Went to an fl shop and they knew the fix right away.
Having RV issues? Connect with others who have been in your shoes.24,278 PostsLatest Activity: Jul 03, 2025
