dropframe's avatar
dropframe
2008 Southwind Kwikee Motor
I have a 2008 Fleetwood Southwind. I am unable to determine which motor I need for my Kwikee steps. The Kwikee sticker with product number and serial number are unreadable. Per the https://www.lci1.com/assets/content/support/sheets/pg-82-ST0501.pdf
identification website, it appears I have the IMGL control unit.
The motor is NOT the Cardone Window Lift Motor #42-3003 (I compared it at auto parts store). From looking at pictures and diagrams it most closely matches "AM Equipment" 214 Series Gearhead Actuator Motor OR 210 Series Gearhead Actuator Motor. http://www.amequipment.com/ame-products/utility-gearhead-motors/#toggle-id-5
Which one is the correct one to get? What is the matching window lift motor from Ford or other car manufacturer that I can get at Autozone or Advance Auto?
FYI, the motor I have has AM and RH2 as well as PETG45 and a month and year (6-07) stamped into the plastic housing. The pinion gear on my motor has 12 teeth (unlike the 9 teeth I see on some websites)
  • I just replaced the motor on my 2001 Beaver coach. I matched it up with one on Amazon and ordered it. I did have to swap the electrical plug out from the old to the new one is all.
  • Those motors are usually protected by an overload relay. Mine would not turn even a bit, but the relay was doing it's job.
    I put my meter onto the motor leads and tried to open the step. Yes, there was voltage there. In a few seconds, the relay cut off the voltage.
    I released the holding bolts a few turns and tried again, presto, worked just fine. I then shimmed up the bolts with some shim stock and it worked again forever (that I owned it).
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
