We are at a campground. One A/C is working the other one will not turn on. It has 50amp but the campground only has 30amp. Any suggestions would be helpful. Thanks
1. Normally you can only run 1 A/C unit on a 30 amp service. If you tried to run two, then you probably tripped a breaker and this is why the other A/C will not come on. Check your breakers for a tripped circuit....
If you are trying to use both A/C while connected to 30 amp service, it probably won't work. Not enough voltage and there is a chance of doing damage to one of the A/C. Should be able to use 1 .
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
