Zaneyk's avatar
Zaneyk
2017 Jayco Greyhawk 29ME Battery box connections
I am replacing my 2017 Jayco 29ME outside marine battery. Unfortunately, I forgot to take a picture of the old connections and now am unsure of the proper cable connections. Can someone send me pictures of their battery box showing the positive/negative cable connections so I do it correctly. I believe the 2016 model wou ld be the same as well. Thanks!
  • I am replacing the Champion 27DC marine battery with the same battery
  • MEXICOWANDERER wrote:
    Group 29 is a group 31 battery that has uni-terminals that allow fitment of studs, posts, clamp, or ring terminals. It specifies the battery ends can be swapped with no compromise in cable accessibility. This cannot be done with a group 24 or group 27, 30, or 31 battery
    Jayco 29 ME IS THE RV MODEL NUMBER, not the battery group:B Doug
  • Group 29 is a group 31 battery that has uni-terminals that allow fitment of studs, posts, clamp, or ring terminals. It specifies the battery ends can be swapped with no compromise in cable accessibility. This cannot be done with a group 24 or group 27, 30, or 31 battery
    Sorry. The description needed clarification. But at least I described the 29, 30, and 31 BCI batteries.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 25, 2025
