lawrosa wrote:
Yes adjustable... I would need access to the dial though....And be able to read the meter.. Dont know if I can do it...
http://www.bestconverter.com/Boondocker-BPCM-60-60-Amp-Adjustable-Power-ConverterCharger_p_585.html#.WrlKcIjwaUk
You want this one instead. Does the same thing but has internal fan, can be mounted so you only need to get at the side with the holes in it, not the top. The right hand hole lets you adjust the voltage pot. The left hand hole is for a switch to choose between fixed three stage standard profile and the adjustable mode where you use the right hand hole to set your voltages. Note the price and free shipping! What a deal!
https://www.amazon.com/Powermax-PM3-75LK-Power-Supply-Light/dp/B01MT636SX/ref=sr_1_24?ie=UTF8&qid=1522093240&sr=8-24&keywords=PowerMax+converter
