- fj12ryderExplorer IIILeaks? It's about twice the pressure. But it might be okay, probably will depend on the state of your plumbing, or rather the state of your RV's plumbing.
- STBRetiredExplorerMost pumps have a pressure adjustment. You should be able to turn it down, even though you probably don't need to. Most city water connections are higher than 20-30 PSI.
- ScottGNomadIt will be fine with the 45 PSI pump.
Even when you connect to city water your going to be at least 40~45 psi in most cases. - Old-BiscuitExplorer III1984 vintage ........
Bet you have 'GRAY' plumbing lines/fittings
It is 'Quest' piping......Polybutylene pipe
The pipe is OK but the aluminum bands/clamps fail.
If you have Copper crimps or threaded fittings it is OK
