MEXICOWANDERER
Sep 21, 2014Explorer
I've been using Euro-Terminals for 20 years. They have a tension tang between the set screw and wires to be clamped. The slotted set screw has a slight interference fit to the housing threads. This means the set screw is not loose and does NOT rely on compression of the conductors to stay tight. Nylon housing. The six gauge model is good for 65 amps at 240vac. This fastener does not loosen over time. it has been a mainstay in my wire management inventory. A pair of 10 gauge wires can be paralleled into one hole with ease.
![](http://www.adafruit.com/images/medium/ID677_MED.jpg)
