Dusty_R
Sep 28, 2014Explorer
mrgreetis wrote:
I learned something new - what a "marrette" is.
Tried finding a definition, that led me to this link
clicky
Never knew that...
Glad you checked it out I did not know either and I'm a retired construction electrician. We always called them "wire nuts". There are a lot of different makes of them.
It's a good practice to tug on each wire, after installing a wire nut to be sure all the wires are caught/holding in the wire nut.
I was working on a job once making joints/connecting on #12 stranded wire. I had made all the joints in a box and was pushing the wires into the box so I could put the cover on, and a wire came out of a wire nut. I thought that I must of not check that one. I fixed that one then went on to the next box, made all the joints in that box, and made sure that I pulled each one in that box, they were good. But when I pushed the wires into the box another joint fell apart. I found out that the wire nuts that I was using were the poorest ones that I had ever used and they were NOT holding the wires like they should.
Dusty
