wa8yxm
Jan 16, 2019Explorer III
Cummins12V98 wrote:
"NOTHING in yoru RV needs 240 volts (Minor exception if you have an ALL ELECTRIC RV that may not be the case) Everythign is 120 volt"
HMMMMM, I have a 220V Washer AND Dryer. I also have 220V Cheap Heat.
Bottom line I would consult a QUALIFIED Electrician.
You will note I too suggested a qualified electrician or at least a licensed one. I won't bore anyone with the list of reasons why.
Your 220 Volt W/D is not designed for RC that's a Residential device I'm sure. But it won't mind 208.. Neither will the cheap heat. Just a few less BTUs.
THe element in my water heater says 240 volt (1500 watt) but it works just fine on 120. only 375 Watts though.
