wa8yxm
Apr 24, 2015Explorer III
5 amp is a lot to push through a LED less you are designing flash bulbs..And with multi-led Panels you would need matched led's and when one burns out the rest become flash bulbs.
But I see it is also a VOLTAGE regulator.. add a simple resistor and your LED's are very happy (one per led or with 5 volts one for every two led's).
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
