dougrainer
Feb 07, 2021Nomad
I wonder if the failures the OP's friends had came from adjusting/checking Torque on HOT wheels, instead of waiting for them to cool to ambient temp? YES, CORRECT recheck of Torque requires you to loosen and THEN tighten and Torque. AND, following the correct Torque sequence. Which is almost 180 degree across each lug nut. Doug
