ktmrfs
Mar 29, 2017Explorer II
MEXICOWANDERER wrote:
Schpeaking of RF generation...
I'm going to attempt to build a Pi filter that will be inserted at the power entry point of an LED fixture. "Hopefully" it will null back fed frequencies from using the entire 12 volt switched circuit as a transmitter. "By prayer and crossed fingers" it will reduce radiation generated by LED regulators. Wonder how an LED reg is going to like its own faraday cage?
lots of the better regulated LED lights are very good for having very low RFI. trouble is you can't tell by looking at the spec's. or the vendor. In my case I got all mine of different bases, etc. from one supplier. however, one specific base style put put lots of RFI, luckily only used in one fixture. all the rest were very good. but the bad ones can be pretty bad.
