Nyfishon's avatar
Nyfishon
A/C compressor not running.
I have a 2013 Whitehawk 28DSBH and the A/C compressor won't kick on. The AC worked yesterday at a different site but will not cool today. The fan will run but I can't seem to get it to cool. The only thing I notice that we may have done wrong was not turning the thermostat off when we left the previous campsite yesterday. It kicked on as soon as we plugged in at the new site. Could the unit being on when plugged in cause an issue? Are there are hidden reset switches? I was on the roof yesterday, capacitors "look" ok, I've checked all the breakers, fuses, etc... Any ideas are appreciated.
  • There is nothing you can do that would cause this problem. I assume RVP(Coleman) AC as that is what Jayco uses. If wall tstat and all upper items seem ok, then the freeze sensor may be bad. Doug
  • Yes Coleman, I checked some wires for loose connection, reset breaker, etc...
  • I would look at your line voltage next or at least listen to see if the compressor is attempting to start
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
