![](data:image/jpeg;base64,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)
This is what a capacitor looks like when the inside has overpressurized, and the top "pops" up. and will require replacement. Also I have tested capacitors and found that they do not have the rated capacitance, so replacing the capacitor is not a bad idea. You might also want to install a SPPE4, it is rated at 120 volts. It can speed up the process of starting the compressor, especially useful while on a generator, or lower voltage.
I would also suggest getting a 'kill-a-watt' from E-bay, they are about $22. It will plug into a receptacle, and give you the line voltage. If it goes below 105 volts, then it is time to shut off the A/C until it improves.
If you frequently want to camp in a RV park that has low voltage in the summertime, then I would also suggest buying a $350 Hughes Autormormer. It will boost the voltage by 12 volts when in use. So 105 volts becomes 117 and you can run the A/C all summer long!
My thought is that you have low voltage to the A/C and it is tripping on high temp / high amperage overload that trips out only the compressor.
http://www.supco.com/eclass.htmGood luck,
Fred.
Porsche or Country Coach!
Kangen.com Alkaline waterEscapees.com
