evergladesgator's avatar
Aug 09, 2017
AC on Class C
Putting this on tech . Figured someone may have worked on ac unit.
Friend has class C. 27'. No tag on ac motor or unit. Fan motor went out. All i know is two speed, double shaft. Carrier unit. Any ideas as to what rpm, hp etc. Thanks for any help.
  • Funny you posting this now, my old Carrier unit is being replaced right now at the repair shop for the same thing. If i can get to look at the old one when they remove it, I will check to see what the tag says ( if there is one). But there is someone on these boards who also had to replace his Carrier unit, His user name is. wa8yxm. Maybe you can send him a private message. He was very helpful when i had questions on my Carrier
  • By the way. There is a label on the motor but no model #. It's a Daewoo motor with a Carrier tag attached.
  • Let your friend know that if he has to replace the A/C there are conversion kits that allow him to keep the Carrier handheld remote control. They are putting one in for me, its a Coleman Mach 15 with the conversion kit to be able to use the Carrier remote, and it will retain the Carrier grille inside the RV. (If his unit is a ducted A/C)
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
