MEXICOWANDERER
Aug 06, 2014Explorer
AC Powered LED Power Supply Design (??)
Noise question.
I am building modular AC (and DC) powered 33 volt LED lamps for various uses.
Area of Question: Where to located switching power supply? In the circuit.
Reason: Noise, electrical type.
Can I use a braided shielded duplex wire between the power supply driver and the lamp?
I would like to locate the driver in a well ventilated bay then run the duplex wire to the lamp module. Weatherpack connector or one of those RC connectors. Easy to disassemble and store.
I am going to carry the AC driver like I just posted a link to, or a boost DC to DC module (I think I posted a link awhile back on that one). Universal connector on the lamp module.
HOWEVER!
I've read comments on the forum about regulated LED lights being so noisy electrically that they caused real problems with other devices. I am trying to cut corners here in the trial-and-error department :)
Thank you!
HOWEVER!
Thank you!
