CT_WANDERER's avatar
CT_WANDERER
Adding 2nd Battery bank
I want to add a second battery bank(2 GC2's). I don't have the room to add anymore batteries to the main bank(4 GC2's). I want to use the second bank mainly to run a 300 watt inverter for the bedroom TV/Sat System. I do not plan on running the inverter at max loads. If I put a relay with #10 wires in that will connect the two banks together will all the battery slowly equalize, when not being drawn on. I was thinking I could put a separate charger for the second bank, or should I just keep them totally separated? Any useful input will be great full. Thanks Gary
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
