- djsamuelNomad
The reviews look good with the exception of some shipping issues. I just purchsed the 15K BTU unit from Recpro to replace my Penguin II from Dometic which was so load I couldn't stand it after 10 years.
The unit I got was an A/C and heat pump and works great. It is SO QUIET it is amazing and the remote is excellent as well. I would highly recomend it. It is more expensive than the units from ETrailer, but they are really nice.
- wa8yxmExplorer IIII posted elsewhere... I had one. and though it worked well and was indeed cheaper than the alternative. When it came time to clean the condenser it was a witch of a job.. THe cover on the condenser is sealed with tape and attached when Bent tabs so I had to cut the tape and unbend the tabe. then the cover for the evap.. Well it's all the same piece of metal. So I ended up bending it in the middle where it was not covering anyhing.. That's my major complaint. both of the other brands I had were easier to clean.
- Home_SkilletExplorer II
