BurbMan's avatar
BurbMan
Jan 10, 2014
AFCIs in an RV
Another post on intermittent electrical problems got me thinking on the subject of Arc Fault Circuit Interrupters (AFCIs). An AFCI is a special circuit breaker that is designed to detect arcing in a circuit that may cause a fire. Arcing could be a neutral-to-ground short, a loose wire, etc.
The National Electric Code now requires AFCI breakers for all branch circuits in a home...I'm not sure if that would apply to RVs or not. Has anyone swapped out their breakers for AFCIs? Any reason that upgrading to AFCIs in your RV isn't a good idea?
Read all about AFCIs here.
