AM_Allan's avatar
AM_Allan
Air conditioners comes on every time the heater does!
I have a new Montana Mountaineer 5th Wheel with about 20 total days of use on it. I thought I had tested everything for problems, so this is likely an issue that started sometime within those 20 days. Now, when the heater comes on, the air conditioner also runs regardless of the temp set on the Dometec Fan/Cool/Furnace type thermostat. I can run the heater with the AC circuit breaker off, but I'd really like to fix this. It's under warranty, but I'd like to avoid dragging it into the dealer if I could do it myself. Any ideas?
