Bob_Landry's avatar
Bob_Landry
AirConditioner Discharge Openings
Are the discharge opening, where the uunit mate with the duct the same size for 13.5 and 15K units. Wondering if new RVs are ducted with larger duct so that either size capacity can be instaled. Have a 15K AC and looking to add a second.
  • Before you add a second AC, check out RV Airflow System. It will boost the ac duct output by 40-50%. I just installed one, but it hasn't been hot enough to really see how much faster rv cools down. I did turn fan on and the air coming out of ducts is much much better.
  • All roof top RV AC holes are 14.5 inches square. Been that way for more than 50 years. Doug
  • wa8yxm's avatar
    wa8yxm
    The A/C consists of 3 or 4 (or 5 in a few cases) parts
    The upper unit. this is the "Guts" of the operation this is what is 13.4 15 or other thousand BTUs.
    The part that goes through the roof, This is the duct adapter and the same is used for both sizes. This part may include electronics and or controls
    The grill (indoor cover
    Optional 4th part: Thermostat on wall
    Optional 5th part: Adapt-a-kit because Carrier was the OEM.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
