MEXICOWANDERER's avatar
Jun 19, 2014
Alternator External Rectifier Linkage
Alternator retains original rectifiers for chassis use, the external rectifier powers the house bank. No separators no switches, no gizmos, and a longer lived alternator...
Use this search term on eBay
Alternator - Quicktifier 420 Heavy Duty External Rectifier Alternator Upgrade
  • Also 2nd battery bank charging is also automatic.
    Rectifiers are rated at 20C. At 150C a 50 amp rectifier may droop to 15 amperes capacity, safe. Couple that with vulnerability to transient voltages (AC compressor clutch, slide-out motor, starting an onboard generator) and the stage is set for your auto parts counterman to smile a broad grin.
    Alternators do not "suck" cool air. When 200F air is drawn -into- the unit what do you suppose does -not- happen? I believe it a near miracle that rectifier bridges and voltage regulators survive this cruelty as well as they do.
    I am tinkering in the MOSFET rectification arena. Fascinating.
  • wa8yxm's avatar
    wa8yxm
    Sch I was going to explaine it but Mr. Wizard beat me to it.
    MOST common alternator failure is the diodes, by doing it the way he's doing it the load on the internal diodes is actually reduced, resulting in a cooler diode stack and longer life.
  • I've replaced my share of alternators
    An external rectifier connected to the house batteries
    Means less heat/load on the internal diodes
    Reducing the chance of failure
    Most alternator failures are diodes, or bearings
    The "regulator" is going to control the output
    Heat damage is accumulative, everyone the diodes get hot the amount of damage increases, reducing the heat, will increase the life
    clikly External Rectifier
  • Cannot see how this would improve alternator durability, as the parallel system is only going to place an additional load on the alternator which was only originally sized to do the chassis???
