mrekim's avatar
mrekim
Aluminum Extrusions For Bulb Seals - where to look??
I want to add a bulb seal to the bottom of my slides to get a better seal when the slides are closed. The wiper seal doesn't do well.
I've found all kinds of bulb seals, but I have yet to find something to insert them into. I realize that I could probably get an aluminum L bracket and attempt to glue a seal to it, but I'd prefer something that was more serviceable.
Is there some place that I can look to find a bulb seal AND an aluminum strip that will hold the seal?
    Search McMaster Carr.
  • Just a hollow round tube. Most slides have them on the top and sides. Here's a photo of one with a t slot mount:
  • Or if I end up with just a D shaped bulb seal and an a piece of aluminum angle then what adhesive can be used to bond the two?
