time2roll
Mar 04, 2015Nomad
The mighty mini is a typical RV panel. It is split into two systems including distribution of 120vac with a main and five branch circuit breakers. You need to supply 120v power from the utility, generator or an inverter.
Separately it has a 12v distribution with a stack of maybe 10 fuses for multiple circuits. The converter is the connection between the 120v and 12v sides. Unfortunately it only goes one way 120v --> 12v The converter will also keep the battery charged as the battery connects on the 12v side. So again the 12v side just distributes 12v power supplied by the converter or direct from the battery.
