MEXICOWANDERER's avatar
Jun 15, 2016
AMAZON.COM AC Plug In Voltmeter
It has a POT! And it's a DROK!
DROK® Flat Plug AC 80-300V Voltage Panel Power Line Volt Test Monitor Gauge Meter AC 110V 220V Digital LCD Voltmeter for RV Boat Camper Household Factory Plug into Outlet Directly to Measure Voltage
by DROK
4.8 out of 5 stars 202 customer reviews
| 3 answered questions
Price: $3.79 + $2.49 shipping
  • Bought a few of these on E Bay for less than $5.
    Nice night light too and I use one in my homemade pedestal checker before hooking up
  • Ah,my bathroom night light. Could someone source a frequency meter in similar fashion?
  • Almot's avatar
    Almot
    RoyB wrote:
    Mine has the GREEN SCALE to remind me where the safe zone is...
    None of my DC VOLTMETERS have a built-in settable alarm to tell me when I am approaching 12.0VDC (appx 50% charge state mode)... Makes me have to keep an eye on it...
    It will likely outlast the owner. No annoying Sci-Fi blue screen either.
    And - yep, you need a solar to keep an eye on those 12V things for you. But you already know this :)
  • I've had one for years too. I love it. Use it in the house too and also when on generator backup power to make sure both legs of the service are even.
    Yes, a great night light.
  • RoyB wrote:
    says the dimensions are 5.1 x 3.8 x 2 inches - guess we old guys can read it...
    Roy Ken
    In typical Amazon fashion, the dimensions given are for the packaging, not the actual product. The meter case is 2.125" x 1.5" x 1.0", plus the plug prongs. The display is 1.625" x 0.875", with 0.75" numerals.
  • RoyB's avatar
    RoyB
    My RV 120VAC VOLTMETER that plugs into a 120VAC receptacle is analog and is still working - guess I'm still good...
    None of my DC VOLTMETERS have a built-in settable alarm to tell me when I am approaching 12.0VDC (appx 50% charge state mode)... Makes me have to keep an eye on it... I've done so many time times I almost already know when the majic number comes up...
    LATE NOTE: I just looked up the DROK meter DM 55-1 specs and it says the dimensions are 55mm x 41mm x 26mm thats 2.1 x 1.6 x 1.0 inches Thats more like it based on whatever the orange thing is it is plugged into in the photo.... AMAZON must have a misprint...
    Roy Ken
  • I have the same one in both my TC and TT. I used the pot in the PCB to calibrate it to my Fluke 87... within 1V or less.
    Nice, simple, little unit. Plenty accurate too... and it even makes a decent nightlight :)
    -Mark
  • I have one. Works great. If you want to adjust it to match, say a quality multi-meter reading there is an adjustment screw inside in the upper right corner...
    If display voltage is too high, adjust potentiometer in counter-clockwise
    If display voltage is too low, adjust potentiometer in clockwise
  • Clicky
    I've had one connected in my motorhome for several years now. It read about 3 volts low when I first got it, but adjusting the calibration pot took care of that easily enough. The plug is non-polorized, so it can be plugged in either way.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
