Gdetrailer
Oct 17, 2021Explorer III
BFL13 wrote:
Lights dim with lower voltage and also draw fewer amps when dimmed, so that fits.
Slower fan speed in the furnace with lower voltage would get to the point the sail switch would open, so that is the safety there.
My 8531 older furnace says the 12v to it should not be above 13.5v. That is in the manual's section about the flame sensor's microamps, but I can't find a minimum voltage specified for when the blower fan gets too slow.
The furnace does work ok when battery charging is happening and the battery voltage is above 13.5v. I have not measured for voltage at the furnace then. Doug R and the other techs here would know about all that.
Part 2--
Not sure it is the same thing for how amps work--I am now looking at the DC-DC charger
With the input of that thing, you must use fatter wire to the battery to keep the amps down and the voltage up.
Could relate to the point made above re wasted amps making heat with voltage drop? Fatter wire means the alternator does not have to do extra amps to make that heat?
Flame sensor could be an issue with a too low of a battery voltage if the control board doesn't have good voltage regulation built in. Flame sensor works on the idea that the flame conducts electricity. So control board places a voltage on the sensor rod. No flame, no current flows. When there is a good flame, the flame will conduct a small amount of electricity which creates a small measurable one way current flow. Controller will monitor the current flow, if not correct current will shut down the furnace..
Potentially you could reduce the voltage to the fan motor to reduce the current drawn but I believe it is in your best interest overall to leave well enough alone as slowing down the fan affects not only your inside air flow but the burner side airflow.
As far as DC-DC setups goes, they work in the same principle as a autoformer does for AC but with DC and perhaps a bit more efficiency.
Lower input voltage will require more current to get a higher voltage at a certain amperage. So say you have a 20A DC to DC power supply and you are taking 13V and changing it to 14V you would draw say 20 amp (260W) on the input but get 18.5A (260W) on the output.. There is no free lunch.. Wattage is the same, but amperage drops..
Using a DC to DC charger, you are simply trying to boost the voltage high enough to get over the voltage lost due to higher resistance of small wiring.
You are also trying to get past the vehicle alternator's regulator which typically tapers down the voltage from the alternator from initial charging voltage after starting of around 14.4V down to 13.8V which basically means your RV battery only gets a tiny trickle charge after a minute or two of engine running..
Keeping in mind, in my example that is assuming 100% efficiency of the DC to DC charger.. Nothing is 100% efficiency in this world and DC to DC chargers are no exception and will run 80%-94% efficient.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
