โOct-27-2021 08:52 AM
โOct-28-2021 08:59 PM
โOct-28-2021 07:38 PM
pianotuna wrote:
You can order one here:
https://www.bradyinstruments.com/products/battery/pro-battery-hydrometer-set-wcorrection-thermometer
โOct-28-2021 12:11 PM
โOct-28-2021 10:33 AM
โOct-28-2021 10:16 AM
โOct-28-2021 07:05 AM
MEXICOWANDERER wrote:
The ambiguity would be found with a hydrometer. There must be a hundred discussions on this forum about hydomerers usage, links, types and brands.
My Samsung cellular goes from 100 to 50% in three hours. Then from 45% to 12% shutdown the next hour. Next to useless.
Go to
Http://www.rollsbatteries.com
Download their battery manual
You have batteries exhibiting classic signs of partial sulfation.
โOct-27-2021 08:02 PM
โOct-27-2021 04:36 PM
โOct-27-2021 04:06 PM
โOct-27-2021 02:22 PM
BFL13 wrote:
What DC load is on the batts while camping for that 12.3 that is not on at home for that 12.6?
You can't tell "90% charge" with a load on the batts. You can get a voltage but can only guess at the % of capacity, and you have to guess at the capacity too, since it changes with temperature.
Your batts are no doubt sulfated somewhat from lack of time at 14.8v and equalizations to 16v from time to time, so they might have more of a voltage drop under load that batteries in better shape.
โOct-27-2021 01:16 PM
Katdaddy wrote:2oldman wrote:Katdaddy wrote:What does 'the solar would show' mean? The panel on the controller? During full sun?
The solar would show the voltage up to 13.00 during the day and then it would again drop to 12.30 after dark.
The readout on the controller and my volt meter would read 13.00. Never had what I would call full sun. The most input I saw was 48 watts. The batteries read 12.30 when we got there and, with solar each day read 12.30 when we left.
โOct-27-2021 01:05 PM
โOct-27-2021 01:04 PM
โOct-27-2021 01:01 PM
pianotuna wrote:
Katdaddy,
90% after sitting idle for 24 hours?
