GordonThree wrote:
Old-Biscuit wrote:
I love some of the suggestions......
pound on it, torch it, heat/chill it
Don't worry......the porcelain lining won't crack
Penetrating oil. Spray it/let it soak
Then tighten a bit to break bond then remove back/forth
since when are they putting porcelain linings in RV wh? I would think all the bouncing and jostling while rolling 10s of thousands of road miles would do more damage to any lining than heating the iron plug with a torch for a few minutes.
no lining in mine, just straight aluminum, I looked in that hole with a flashlight once.
From Suburban's website:
Select electronically controlled water heaters are perfect for adverse weather conditions with its direct spark ignition(DSI) featuring a remote switch which can be used to conveniently light the water heater from inside your camper/RV! Heaters are porcelain-lined and feature an electrolytic action absorbing anode rod extending your heaters life for years to come. Whether the heater is 3, 6, 10, or 12 gallon it's no matter at 10.2 gallons it has the fastest recovery the industry has to offer providing more gallons of heated water for your pleasure. A heat retaining Copolymer jacket is fitted to keep the heat close, ensuring none escapes. Recover even more utilizing the 1,440 watt element with optional electric and gas water heaters that can recover up to 6 gallons per hour. On select models the Re-ignitor eliminates the need to relight your pilot keeping the heat recovery action consistent. Installation, operation, and maintenance are all easy as they are simple.
