StirCrazy
Sep 11, 2020Moderator
Thermoguy wrote:
So, not to bring up an old thread but wanted to update and have a new question.
After the first night of our trip, batteries proved they were going to be an issue, and with the cold weather ended up running our furnace for just a little bit in the morning. So, to not have to worry, stopped and bought 2 6V GC batteries. Piece of mind is nice. Not sure if I could have gotten away without and just struggled, but didn't want to struggle especially with overnight lows in the 40's.
So, now my question. My battery boxes are too small for the 6V GC Battery, they are taller. I have a 5th wheel so the boxes are vented with a tube, not open like a travel trailer box. I have been searching a few websites and have not found the taller boxes. I went to a local RV supply and they can order them, but I gave up when the guy couldn't find how to order them or what the cost was. He admitted he wasn't the parts guy.
Any ideas where to find these? Also, is it better to buy the same 2 boxes like the original batteries or buy a single box that fits both batteries on the one side. If I go with the original setup I have to figure out a new battery cable as my original cables were for a 12v setup and don't have the correct connections to go straight from battery to battery. I would want to replace that wire with the correct size battery wire and new connections.
Any advice is appreciated. Thanks
I took out the boxes in the front of my 5th wheen and fastened two boxes designed to hold 2 6v batteries in each one. as for the venting that whole front space is open to the outside in mine so it wasnt an issue we just left the top vent through the wall in place. if yours are in a sealed compartment just take the hose off the factory box and cut a hole in the 6v box lid and fasten it to that.
Steve
