โMar-10-2014 07:19 AM
โMar-10-2014 07:18 PM
Bill.Satellite wrote:
What I believe you are looking for can be searched out with the use of a Kill-A-Watt meter. You plug each device into this meter and it reads exactly how much power the device uses. It may take a few days to plug, run, read and add up all the devices using all the power, but when you are done you can accurately measure how much power you are using so you can determine how much power you need.
โMar-10-2014 05:56 PM
โMar-10-2014 05:38 PM
โMar-10-2014 05:30 PM
pianotuna wrote:
Hi,
I went for 14 years with only solar, as far as camping goes. I mostly boondock. I did have a genny--but it was to run the block heater in winter time. I left it behind when camping. It failed and the replacement was no good. (mea culpa)
Then I switched to full time and I thought a genny was needed. Turns out I would have been better to do more solar. The new genny has run less than fifty hours in 10 months. Over 1/4 the run time is exercising it. (I.E. running it for no good reason).
Since I started full timing in Oct, I've not run the generator *once* except to exercise it.
โMar-10-2014 05:02 PM
โMar-10-2014 04:46 PM
โMar-10-2014 11:24 AM
โMar-10-2014 11:08 AM
โMar-10-2014 10:58 AM
RJsfishin wrote:
Can't believe you solar guys ! Like solar is the answer to everyone's problem.
Seems ya all forget that solar needs sun ! Buy a small quiet generator first, then you don't have to worry what each little thing in your rig is using.
Go camping, then you will find out how much your daily AH requirements are.
Here's a poor many battery monitor,.......
If you have the sat tv playing, and a couple lites on, and the water pump comes on, and you don't notice any noticeable lite dimming, or the sat tv skippin a beat, you are well over 50% yet, and good till morning.
I couldn't care less what each dc item is drawing, I just care how often I need to recharge !
And I dint just start dry campin yesterday.
But yep, I got ammeters and voltmeters all over the place, but I know how often I need to recharge, and that doesn't change by much.
And yep, my solar works fine, when the sun is shining, but that hasn't happened in a week now.
โMar-10-2014 10:06 AM
โMar-10-2014 09:15 AM
โMar-10-2014 08:29 AM
โMar-10-2014 08:06 AM
uintafly wrote:
Over the course of the next few months I really want to figure out how much juice I have in my batteries and what draws them down. We do a fair amount of boondocking so I would like to know timelines of how long I can go without briging a gen. I have a multimeter and can measure how full my batteries are, but how do I measure what is drawing what, and how many amp hours I have left? A couple times last year we would park our trailer and use it in consecutive weekends, but the parasitic draws would really run the batteries down over the course of the week, to the point I didn't really trust it to leave any perishables in the fridge for fear it would kick off. Any advice woud be greatly appreciated.
Thanks,
Chris
โMar-10-2014 07:55 AM
