MEXICOWANDERER's avatar
Jun 21, 2017
Another Megawatt Upgrade Want To Post Article
Pictures and text.
Is there an easy to use upload service that can retain a created article? The upgrade article would include the entire process divided into chapters.
Easy disassembly & reassembly
How to choose, buy and install a voltage adjustment potentiometer
If needed, how to replace the weakest components (caps and rectifiers) in the Megawatt. This turns the Megawatt into one tough charger.
These things are not nerd techhie grade mods. If you can handle a cheap 15 watt soldering pencil, you can do this stuff so easy it hurts.
But I need a kindergartener's grade upload site to start the process.
Any ideas?
Thank You
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
