dougrainer
Mar 02, 2020Nomad
enblethen wrote:
OP asked about anti-siphon for black water flush. This is also known as a backflow
preventer. It is in-line with the flush line.
It is not an air gap. The tank is vented through the roof.
Yes, the tank is vented thru the roof. IF YOU REMOVE THE ANTISIPHON VALVE AND PLUMB STRAIGHT THRU(REMOVING THE VALVE) IT WILL VENT BACK THRU TO THE INLET FITTING. You will get Black tank odor in the Water Bay in transit. You can stop that by installing a screw on plug on the BT inlet fitting. Or, just install a standard City Water inlet with the built in check valve. Doug
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
