DAS26miles's avatar
DAS26miles
Jul 31, 2019
Any issue running PD converter charge without battery?
Will Removing the coach battery prevent using 12v or 110v for AIr conditioning using the PD converter charger with genny or shoreline power?
  • PD converter is fine. Anything 12v that powers off the 12v stack of fuses is fine including the air conditioner. Your slide might be powered direct off the battery so may become disconnected when the battery is removed. Otherwise no worries.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
