msmd1's avatar
msmd1
Aqua Magic IV cleaning
I have noticed that there is a cavity underneath the slide valve to flush the toilet that collects a considerable amount of fecal matter. There is mold and mildew and smell! Any suggestions on cleaning products and perhaps a better toilet solution that does not have this inaccessible cavity? I removed the toilet to replace the flush valve (after it spewed water everywhere for a few minutes) and found the source of the smell. Thank you in advance.
  • wyocowboy00 wrote:
    I think you can add an optional hand sprayer to that toilet. Give Thetford a call.
    Not an option on OPs Aqua Magic IV and wouldn't be a good idea with the 'open cavity' issue of that toilet design
  • I think you can add an optional hand sprayer to that toilet. Give Thetford a call.
  • Check out the Thetford Aqua Magic Residence, Style II and Style Plus
    Also the Dometic 320
    The optional Hand Sprayer is great for rinsing down-tube (vs that open cavity)
    Using your preferred version of tank wand to help clear the tank of "debris" will also clear the toilet throat.
Having RV issues? Connect with others who have been in your shoes.24,277 PostsLatest Activity: Jul 02, 2025
